Re: Bore a12 how far can you go
From Wellington New Zealand
I'm sceptical of a 79mm bore in an A12 block....77 was the utter limit for me, like I say, it took 5 blocks to find one that would take it...
Someone here (dodgeman perhaps) has put an A14 crank in an A12A block, which is interesting from an engineering point of view, but seems like a lot of work to achieve what an A14 does anyway....
Posted on: 2005/4/6 1:21
Subject Poster Date
     Bore a12 how far can you go greg12 2005/4/3 12:27
       Re: Bore a12 how far can you go 2332owner 2005/4/3 13:47
         Re: Bore a12 how far can you go tsillay 2005/4/3 23:25
       Re: Bore a12 how far can you go datral_10 2005/4/4 2:06
       Re: Bore a12 how far can you go vixen 2005/4/4 4:08
       Re: Bore a12 how far can you go D 2005/4/4 16:32
         Re: Bore a12 how far can you go D 2005/4/5 9:49
           Re: Bore a12 how far can you go tsillay 2005/4/6 1:21
             Re: Bore a12 how far can you go D 2005/4/6 2:22
               Re: Bore a12 how far can you go L18_B110 2005/4/6 6:53
                 Re: Bore a12 how far can you go Dodgeman 2005/4/6 7:21
                   Re: Bore a12 how far can you go L18_B110 2005/4/6 9:00
                     Re: Bore a12 how far can you go Dodgeman 2005/4/6 14:35
                       Re: Bore a12 how far can you go L18_B110 2005/4/7 0:59
                         Re: Bore a12 how far can you go pro240c 2005/4/7 4:51
                         Re: Bore a12 how far can you go chowdozer 2005/4/7 6:40
                           Re: Bore a12 how far can you go L18_B110 2005/4/7 7:02
                             Re: Bore a12 how far can you go D 2005/4/7 8:55
                               Re: Bore a12 how far can you go pro240c 2005/4/7 9:55
                                 Re: Bore a12 how far can you go A14force 2005/4/7 10:47
                                   Re: Bore a12 how far can you go Dodgeman 2005/4/7 12:37
                                     Re: Bore a12 how far can you go 1200GXman 2005/4/7 13:14
                             Re: Bore a12 how far can you go chowdozer 2005/4/7 15:26
             Re: Bore a12 how far can you go Dodgeman 2005/4/6 6:49
