Re: sr20de clutch problems
From Sydney Australia
Mine had similar problems.
Check the level of fluid in the master cyl and look for any signs of leakage. Because of the way the clutch pedal is set up if you push the clutch in not streight it will cause the piston in the master cyl to wear the inside of the master causing leakage. Just pull it off and get it re sleaved if thats the problem.
Also when my slide bearing went (was in rainy weather in the shire also lol) the symptoms were similar as it wouldnt disengage and engage properly is there any rattleing feeling in the pedal?
Just PM me if ya want me to have a look for you im in the shire too.
Posted on: 2005/4/13 2:55
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Subject Poster Date
     sr20de clutch problems Mr_Turbo 2005/4/12 9:35
       Re: sr20de clutch problems dattodude 2005/4/12 10:23
         Re: sr20de clutch problems COUP1200 2005/4/12 11:57
           Re: sr20de clutch problems 731200 2005/4/13 2:55
             Re: sr20de clutch problems dattodude 2005/4/13 3:02
               Re: sr20de clutch problems Mr_Turbo 2005/4/13 8:24
                 Re: sr20de clutch problems 731200 2005/4/14 2:26
                   Re: sr20de clutch problems Mr_Turbo 2005/4/14 8:13
                     Re: sr20de clutch problems 731200 2005/4/14 8:26
                       Re: sr20de clutch problems Mr_Turbo 2005/4/14 8:47
                         Re: sr20de clutch problems 731200 2005/4/14 11:04
                           Re: sr20de clutch problems Mr_Turbo 2005/4/17 11:07
                             Re: sr20de clutch problems Mr_Turbo 2005/4/24 2:01
