Re: Question on compression ratio
From Brisbane, Narangba
10.1 is not the max it is just the best all rounder for a street engine. 10.5 is still ok but you have to be a little more careful. Cold intake temps etc for hot driving days. Also you can retard the timing a little but you will lose the gain of the higher comp. Fuel injected engines can run good compression ratios because the air and fuel is mixed precisley plus alot have anti knock sensers to stop any pinging.
I have around 10.1 and the main difference I noticed was and increase in torque over standard.
Posted on: 2005/5/20 8:08
Subject Poster Date
     Question on compression ratio converted 2005/5/19 13:21
       Re: Question on compression ratio Freak 2005/5/19 13:28
       Re: Question on compression ratio Losadel 2005/5/19 13:32
         Re: Question on compression ratio WhiteSedan 2005/5/19 13:42
         Re: Question on compression ratio Freak 2005/5/19 13:50
       Re: Question on compression ratio vex66 2005/5/19 13:51
         Re: Question on compression ratio converted 2005/5/19 13:54
           Re: Question on compression ratio vex66 2005/5/19 14:22
             Re: Question on compression ratio Meat_rack 2005/5/19 14:26
               Re: Question on compression ratio vex66 2005/5/19 14:31
                 Re: Question on compression ratio A14force 2005/5/20 7:55
                   Re: Question on compression ratio Freak 2005/5/20 8:08
                   Re: Question on compression ratio nzdatman 2005/5/20 8:11
                   Re: Question on compression ratio Coops 2005/5/20 8:15
                     Re: Question on compression ratio converted 2005/5/20 15:50
                       Re: Question on compression ratio killer1200 2005/5/22 13:28
         Re: Question on compression ratio WhiteSedan 2005/5/19 13:58
           Re: Question on compression ratio Meat_rack 2005/5/19 14:02
       Re: Question on compression ratio lamb_daiquiri 2010/6/7 14:17
