Re: a15ett just loose flywheel bolts it seems
From Millgrove Vic OZ
A14force,
I get steel shaft turned down to the same dimension as the drill hole, cut the roll pins to length chamferer theends and tap them in to the holes with loctite (601) shaft fit.
Posted on: 2005/6/5 13:24
Cheers Feral
Subject Poster Date
     a15ett just loose flywheel bolts it seems 1200rallycar 2005/6/1 12:13
       Re: a15ett just loose flywheel bolts it seems 1200rallycar 2005/6/1 12:19
         Re: a15ett just loose flywheel bolts it seems D 2005/6/1 13:37
           Re: a15ett just loose flywheel bolts it seems B120dat 2005/6/1 14:11
         Re: a15ett just loose flywheel bolts it seems Dodgeman 2005/6/1 15:40
           Re: a15ett just loose flywheel bolts it seems L18_B110 2005/6/2 0:37
             Re: a15ett just loose flywheel bolts it seems converted 2005/6/2 0:47
               Re: a15ett just loose flywheel bolts it seems matbighat 2005/6/2 1:14
       Re: a15ett just loose flywheel bolts it seems 1200rallycar 2005/6/2 10:27
         Re: a15ett just loose flywheel bolts it seems feral 2005/6/4 13:42
           Re: a15ett just loose flywheel bolts it seems A14force 2005/6/5 0:50
             Re: a15ett just loose flywheel bolts it seems tom210 2005/6/5 2:35
               Re: a15ett just loose flywheel bolts it seems Mawler1 2005/6/5 8:00
             Re: a15ett just loose flywheel bolts it seems feral 2005/6/5 13:24
               Re: a15ett just loose flywheel bolts it seems Dodgeman 2005/6/5 15:10
                 Re: a15ett just loose flywheel bolts it seems phunkdoktaspok 2005/6/5 15:28
