Re: TRX SSS Box with a L16 in a 1200??
Both the SSS & the follow-on TRX gearboxes are perfectly good units, so don't shy away from a good deal if only because you think they are inferior. Theyre not, but they are a little diferent.
It's the model code TRX SSS that i found a bit odd. The SSS box probably came from a 200B SSS while the TRX was the sporty version of the following Bluebird range.
See if you can figure out the position of reverse gear in the shift pattern & we can tell you which box it is. [either 'left & foward', or 'right & back']
Posted on: 2005/6/26 3:33
Love your Datsun.
Treat it well.
Subject Poster Date
     TRX SSS Box with a L16 in a 1200?? N8 2005/6/25 4:20
       Re: TRX SSS Box with a L16 in a 1200?? BigV 2005/6/25 5:04
       Re: TRX SSS Box with a L16 in a 1200?? Dodgeman 2005/6/25 9:27
         Re: TRX SSS Box with a L16 in a 1200?? matty 2005/6/25 13:39
           Re: TRX SSS Box with a L16 in a 1200?? N8 2005/6/26 1:53
             Re: TRX SSS Box with a L16 in a 1200?? Dodgeman 2005/6/26 3:33
               Re: TRX SSS Box with a L16 in a 1200?? N8 2005/6/27 2:34
                 Re: TRX SSS Box with a L16 in a 1200?? L18_B110 2005/6/27 8:38
                   Re: TRX SSS Box with a L16 in a 1200?? N8 2005/6/27 9:39
                 Re: TRX SSS Box with a L16 in a 1200?? Dodgeman 2005/6/27 11:01
       Re: TRX SSS Box with a L16 in a 1200?? sticks 2005/6/26 5:35
