Re: Do Wide Tyres = Better Grip?
From Sydney, Australia
Not so. (Converted posted at the same time, so this doesn't reference his post)
The formula for calculating "static friction", does not have an "area" component.
Ff = uN
However, when a tyre is under load, the cross-section of the tyre does not have a uniform "static co-efficient of friction", as u (mew) changes with temperature, nor does the tyre have equal force (Newtons) on the crosssection of the tyre on the ground.
So as you can see, it's all rather complex.
The basic reason for having wider tyres is that they last longer (if both are same compound). There is more rubber supporting the load of the car, allowing the tyres to be softer, which changes the u (mew= static friction constant) to be more favourable to grip. The bigger tyres also dissapate the heat better, keeping the crosssectional tyre temperature more consistant.
I believe this is the best tyre explanation.
If tyres didn't get hot, skinny ones would be the best.
Posted on: 2005/7/8 9:14
Subject Poster Date
     Do Wide Tyres = Better Grip? Coops 2005/7/8 8:06
       Re: Do Wide Tyres = Better Grip? sidedraught 2005/7/8 8:24
         Re: Do Wide Tyres = Better Grip? Frodaddy 2005/7/8 8:30
           Re: Do Wide Tyres = Better Grip? sikdatto1200 2005/7/8 8:38
             Re: Do Wide Tyres = Better Grip? snowy 2005/7/8 8:52
             Re: Do Wide Tyres = Better Grip? Ash 2005/7/8 8:52
               Re: Do Wide Tyres = Better Grip? Frodaddy 2005/7/8 8:57
             Re: Do Wide Tyres = Better Grip? converted 2005/7/8 9:07
         Re: Do Wide Tyres = Better Grip? dattodevil 2005/7/8 8:34
           Re: Do Wide Tyres = Better Grip? dattodude 2005/7/8 9:14
             Re: Do Wide Tyres = Better Grip? Frodaddy 2005/7/8 9:18
               Re: Do Wide Tyres = Better Grip? B210sleeper 2005/7/8 18:42
                 Re: Do Wide Tyres = Better Grip? Dodgeman 2005/7/10 12:12
               Re: Do Wide Tyres = Better Grip? killer1200 2005/7/8 18:57
                 Re: Do Wide Tyres = Better Grip? converted 2005/7/9 0:21
       Re: Do Wide Tyres = Better Grip? Rogue 2005/7/9 11:21
         Re: Do Wide Tyres = Better Grip? matty 2005/7/10 9:34
           Re: Do Wide Tyres = Better Grip? L18_B110 2005/7/10 11:48
             Re: Do Wide Tyres = Better Grip? converted 2005/7/10 12:19
               Re: Do Wide Tyres = Better Grip? hotrod88 2005/7/10 18:36
                 Re: Do Wide Tyres = Better Grip? B210sleeper 2005/7/10 22:42
