Re: MAX BORE SIZE?
Thanx Errol I was thinking of trying to match the bore of the ka24e for the 12 valve conversion but I guess I better stick to 87.5 and mill the head as in the next webpage...
http://home.att.net/~MabuhayCarlos/Headwork.html
Though it might not help.
Does 88mm need sonic testing?
Which is the L18W? is it a pollution type block or pre pollution? I`ve had enough of the EPA in the past and will need to be careful.
Also I know it might sound absurd but how much could I deck the block disregarding the chain tension? Im interested in using a 73.7mm stroke L16 crank and 130mm l18 rods or 128mm rods. Im trying to fit the L series in a 1000 and would like to make it less tall and yes I know its better to have longer rods for performance. The a14,a15 blocks are almost 6cm shorter than the L18 and the a12 around 7.5cm shorter. Is taking that much out of an L impossible even if I could get a the right rods, pistons and chain setup? This is just a theorotical question(s) as I know very little of the L.
Posted on: 2005/7/24 11:38
Subject Poster Date
     MAX BORE SIZE? D 2005/7/23 12:45
       Re: MAX BORE SIZE? feral 2005/7/23 14:20
         Re: MAX BORE SIZE? D 2005/7/24 11:38
           Re: MAX BORE SIZE? Nissan4Eva 2005/7/24 19:29
             Re: MAX BORE SIZE? D 2005/7/26 1:56
