Re: Stanza strut/brake upgrade- What springs & shocks are people running?
From Stray-ya
Update.
Got the stanza struts in. As datsic said they give about a 2" lift and sh!tloads of positive camber. no good.
the problem: 1200 struts are 615mm from hat to control arm, stanza & 120y are both 660mm, so you have 45mm to make up. When you combine this with with the stiffer stanza springs it blows out further.
I replaced the stanza springs (400mm free length, 11 coils) with the 1200 springs 325mm free length, 9 coils. this gave an approximately standard ride height.
I then cut down the stanza springs to 320mm (which is the shortest you can go on them and still maintain some pre load) and got a ride height that was a bit lower ( I have yet to measure it, but 2 1/2 to 3 finger gap between tyre and guard instead of 4-5 finger as standard.
All measurements were done using the stock rims. (brake calipers were not on the struts at the time)
I am concerned about bump clearance for this conversion. You are supposed to maintain 2/3 of original bump, so to keep this conversion legal, I suspect you would have to keep a stock ride height.
Posted on: 2005/9/26 3:01
Subject Poster Date
     Stanza strut/brake upgrade- Camber/castor specs from other upgrades. Grunterhunter 2005/9/6 12:45
       Re: Stanza strut/brake upgrade- cant find the damn info in the archives boofhead 2005/9/6 12:57
         Re: Stanza strut/brake upgrade- cant find the damn info in the archives Grunterhunter 2005/9/6 13:19
           Re: Stanza strut/brake upgrade- cant find the damn info in the archives boofhead 2005/9/6 13:43
             Re: Stanza strut/brake upgrade- cant find the damn info in the archives Grunterhunter 2005/9/6 15:42
               Re: Stanza strut/brake upgrade- cant find the damn info in the archives dattoman_1000 2005/9/6 15:50
                 Re: Stanza strut/brake upgrade- cant find the damn info in the archives Grunterhunter 2005/9/7 2:34
                   Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. Grunterhunter 2005/9/11 8:45
                     Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. datsik 2005/9/11 12:21
                       Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. Grunterhunter 2005/9/12 2:59
                         Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. pro-240c 2005/9/12 7:34
                           Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. Grunterhunter 2005/9/12 7:52
                             Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. datsik 2005/9/14 5:42
                               Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. Grunterhunter 2005/9/14 8:15
                                 Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. Grunterhunter 2005/9/18 7:18
                                   Re: Stanza strut/brake upgrade- more info, measurements & unsprung weight. boofhead 2005/9/18 9:10
                                     Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/9/19 2:48
                                       Re: Stanza strut/brake upgrade- What springs & shocks are people running? Anonymous 2005/9/19 10:26
                                         Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/9/19 10:36
                                           Re: Stanza strut/brake upgrade- What springs & shocks are people running? datb110 2005/9/23 12:01
                                             Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/9/25 8:42
                                               Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/9/26 3:01
                                                 Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/10/14 12:01
                                                   Re: Stanza strut/brake upgrade- What springs & shocks are people running? BigV 2005/10/15 1:29
                                                     Re: Stanza strut/brake upgrade- What springs & shocks are people running? 1600Kid 2005/10/15 15:15
                                                       Re: Stanza strut/brake upgrade- What springs & shocks are people running? Grunterhunter 2005/10/17 11:08
                                                         Re: Stanza strut/brake upgrade- What springs & shocks are people running? BigV 2005/10/17 15:37
                                                           Re: Stanza strut/brake upgrade- What springs & shocks are people running? COUP1200 2005/10/18 0:40
                                                             Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/10/30 5:51
                                                               Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/24 4:03
        Re: Stanza strut/brake upgrade- Back on the road. 1200coupe 2005/11/24 4:28
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/24 4:54
        Re: Stanza strut/brake upgrade- Back on the road. phunkdoktaspok 2005/11/24 7:47
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/24 10:41
        Re: Stanza strut/brake upgrade- Back on the road. 1200coupe 2005/11/24 23:30
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/25 1:24
        Re: Stanza strut/brake upgrade- Back on the road. 1200coupe 2005/11/25 1:46
        Re: Stanza strut/brake upgrade- Back on the road. nzdatman 2005/11/25 2:27
        Re: Stanza strut/brake upgrade- Back on the road. 1200coupe 2005/11/25 3:02
        Re: Stanza strut/brake upgrade- Camber/castor specs from other upgrades. Grunterhunter 2005/11/25 11:16
        Re: Stanza strut/brake upgrade- Camber/castor specs from other upgrades. Grunterhunter 2005/11/28 7:03
        Re: Stanza strut/brake upgrade- Back on the road. nzdatman 2005/11/26 4:31
        Re: Stanza strut/brake upgrade- Back on the road. Cable_Tie 2005/11/26 6:01
        Re: Stanza strut/brake upgrade- Back on the road. nate 2005/11/26 8:57
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/28 1:37
        Re: Stanza strut/brake upgrade- Back on the road. L18_B110 2005/11/28 2:46
        Re: Stanza strut/brake upgrade- Back on the road. AdamBDA 2005/11/28 2:48
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/28 3:16
        Re: Stanza strut/brake upgrade- Back on the road. 1200coupe 2005/11/28 4:26
        Re: Stanza strut/brake upgrade- Back on the road. AdamBDA 2005/11/28 7:50
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/28 8:33
        Re: Stanza strut/brake upgrade- Back on the road. AdamBDA 2005/11/28 9:44
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2006/5/6 8:00
        Re: Stanza strut/brake upgrade- Back on the road. phunkdoktaspok 2005/11/24 7:40
        Re: Stanza strut/brake upgrade- Back on the road. Grunterhunter 2005/11/24 10:27
