Re: HELP lose flywheel
From Taupo New Zealand
Interesting thread.... I'm going to make sure I don't miss a gear!
When these flywheels come loose, do they shear all the bolts or do the bolts just loosen? Because if they are shearing, I can't see loctite helping. Also if you use loctite you can't use oil on the threads, and if the torque settings are given with oil as the lube, if you do they up with loctite you won't get the same tension in the bolt for a given torque setting. Overtightening is playing fire because you could reach the yield strength of the bolt- then you're in the ####e for sure.
Having the two fitted bolts like R-fast said sounds like a good idea, but I think if the bolts are shearing, extra dowels would be even better as they are sharing the shear load out a bit more, reducing the load on each bolt.
Posted on: 2005/9/27 7:49
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Subject Poster Date
     HELP lose flywheel olboy 2005/9/25 8:45
       Re: HELP lose flywheel Meat_rack 2005/9/25 9:09
         Re: HELP lose flywheel olboy 2005/9/25 9:19
           Re: HELP lose flywheel Meat_rack 2005/9/25 9:26
             Re: HELP lose flywheel olboy 2005/9/25 9:32
               Re: HELP lose flywheel MLS 2005/9/25 10:12
                 Re: HELP lose flywheel olboy 2005/9/25 10:21
                   Re: HELP lose flywheel A14force 2005/9/25 10:47
                   Re: HELP lose flywheel MLS 2005/9/25 11:12
               Re: HELP lose flywheel MLS 2005/9/25 11:15
                 Re: HELP lose flywheel Dodgeman 2005/9/25 11:37
                   Re: HELP lose flywheel olboy 2005/9/25 11:46
                     Re: HELP lose flywheel Dodgeman 2005/9/25 11:50
                       Re: HELP lose flywheel olboy 2005/9/25 12:02
                         Re: HELP lose flywheel Dodgeman 2005/9/25 13:06
                           Re: HELP lose flywheel Cable_Tie 2005/9/25 23:51
                             Re: HELP lose flywheel COUP1200 2005/9/26 0:36
                               Re: HELP lose flywheel dattoman_1000 2005/9/26 5:06
                                 Re: HELP lose flywheel R-fastmotorsport 2005/9/26 7:43
                                   Re: HELP lose flywheel olboy 2005/9/26 9:34
                                     Re: HELP lose flywheel b310gx 2005/9/26 11:42
                                       Re: HELP lose flywheel olboy 2005/9/26 22:06
                                         Re: HELP lose flywheel benny 2005/9/26 23:22
                                           Re: HELP lose flywheel R-fastmotorsport 2005/9/27 0:12
                                           Re: HELP lose flywheel COUP1200 2005/9/27 1:02
                                             Re: HELP lose flywheel nzdatman 2005/9/27 7:49
                                               Re: HELP lose flywheel olboy 2005/9/27 9:23
                                                 Re: HELP lose flywheel Dodgeman 2005/9/27 11:35
                                                   Re: HELP lose flywheel olboy 2005/9/27 11:49
                                                   Re: HELP lose flywheel feral 2005/9/28 0:01
                                                     Re: HELP lose flywheel olboy 2005/9/28 3:39
                                                       Re: HELP lose flywheel feral 2005/9/29 9:14
                                                         Re: HELP lose flywheel dattoman_1000 2005/9/29 12:00
                                                           Re: HELP lose flywheel olboy 2005/9/29 12:11
                                                             Re: HELP lose flywheel COUP1200 2005/10/17 1:46
                                                               Re: HELP lose flywheel BigV 2005/10/17 4:08
        Re: HELP lose flywheel olboy 2005/10/17 9:38
        Re: HELP lose flywheel A14force 2005/10/19 9:13
        Re: HELP lose flywheel olboy 2005/10/19 9:38
        Re: HELP lose flywheel feral 2005/10/19 14:42
       Re: HELP lose flywheel converted 2005/9/25 12:54
