Re: Water temperature sensor stuck in block!
From Bunbury Western Australia
yeah mate a copper drift is a piece of solid copper rod that is used to direct force to one area the size of the diameter of the drift, like you could possibly knock it into the temp sensor reccess.... I think, but possibly the sensor will not go through that way, I can't remember on mine but I think the heat gun idea could get the metal to expand a tad and that could all be enough to loosen it enough to come out, plus when the metal area expands, the penetrating lubricant may find it's way to the concerning area and free it up
Posted on: 2005/10/18 2:51
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Subject Poster Date
     Water temperature sensor stuck in block! Mildman 2005/10/17 12:56
       Re: Water temperature sensor stuck in block! dattodude 2005/10/17 13:47
         Re: Water temperature sensor stuck in block! 1200rallycar 2005/10/17 13:50
           Re: Water temperature sensor stuck in block! 120fly 2005/10/17 14:03
           Re: Water temperature sensor stuck in block! Dodgeman 2005/10/17 14:08
             Re: Water temperature sensor stuck in block! Mildman 2005/10/17 14:41
               Re: Water temperature sensor stuck in block! blofly 2005/10/17 15:06
                 Re: Water temperature sensor stuck in block! B210sleeper 2005/10/17 22:27
                 Re: Water temperature sensor stuck in block! Mildman 2005/10/18 0:35
                   Re: Water temperature sensor stuck in block! blofly 2005/10/18 2:51
                     Re: Water temperature sensor stuck in block! Mildman 2005/10/18 3:29
                       Re: Water temperature sensor stuck in block! blofly 2005/10/18 4:44
                         Re: Water temperature sensor stuck in block! Mildman 2005/10/18 6:11
                           Re: Water temperature sensor stuck in block! blofly 2005/10/18 7:41
                             Re: Water temperature sensor stuck in block! COUP1200 2005/10/18 7:51
                               Re: Water temperature sensor stuck in block! 1200rallycar 2005/10/18 12:18
                                 Re: Water temperature sensor stuck in block! Mildman 2005/10/21 5:52
                                   Re: Water temperature sensor stuck in block! blofly 2005/10/21 7:16
                                     Re: Water temperature sensor stuck in block! dattodevil 2005/10/21 8:30
                                       Re: Water temperature sensor stuck in block! Mildman 2005/10/22 0:15
                                         Re: Water temperature sensor stuck in block! datto1200ute_qld 2005/10/22 13:48
