Re: Q: 120Y Disc conversion for 1200 ute???
From Melbourne, Victroria
G'day there ...
Yes the 120Y tops will raise your car a fair bit.
It is not hard from (10 yr old) memory to swap the strut tops (and bearing and spring tops. may want to consider which springs to use).
I also think there are some variations with the steering arms (under the struts)
I'd be using the ones that came with the struts.
With the mastercyl, no real prob (unless it has as a booster - why would you???)
Brake lines - you could start with the 120Y ones, but prob easiler to start from scratch.
I could help with the brake lines and I'm chasing up a new bmc for someone else at present.
Simon
www.datsunparts.com.au
Posted on: 2005/10/26 22:09
Subject Poster Date
     Q: 120Y Disc conversion for 1200 ute??? bcg 2005/10/25 12:14
       Re: Q: 120Y Disc conversion for 1200 ute??? oan878 2005/10/26 12:26
         Re: Q: 120Y Disc conversion for 1200 ute??? WhiteSedan 2005/10/26 13:00
           Re: Q: 120Y Disc conversion for 1200 ute??? bcg 2005/10/26 13:05
             Re: Q: 120Y Disc conversion for 1200 ute??? sbre 2005/10/26 22:09
               Re: Q: 120Y Disc conversion for 1200 ute??? bcg 2005/10/27 6:55
                 Re: Q: 120Y Disc conversion for 1200 ute??? Cable_Tie 2005/10/27 7:56
                 Re: Q: 120Y Disc conversion for 1200 ute??? Grunterhunter 2005/10/27 8:00
                   Re: Q: 120Y Disc conversion for 1200 ute??? bcg 2005/10/27 12:30
             Re: Q: 120Y Disc conversion for 1200 ute??? pro-240c 2005/10/28 4:53
       Re: Q: 120Y Disc conversion for 1200 ute??? rallydatsun 2005/10/27 15:04
       Re: Q: 120Y Disc conversion for 1200 ute??? uterous 2005/10/27 17:37
       Re: Q: 120Y Disc conversion for 1200 ute??? uterous 2005/10/27 17:55
