Re: A15 dyno results [and new head gasket needed]
From Cape Town, South Africa
So I'm a fool...
"Can you confirm those readings are with the throttle wide open..."
Now it's showing 154psi for cyl3 and 147psi for cyl4.
Doh, back to the ignition or carbs I guess.
Posted on: 2005/12/17 14:52
Subject Poster Date
     A15 dyno results [and new head gasket needed] ptomli 2005/12/13 10:42
       Re: A15 dyno results [and new head gasket needed] kegs 2005/12/13 10:48
         Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/13 11:00
           Re: A15 dyno results [and new head gasket needed] Freak 2005/12/13 11:31
             Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/13 11:34
               Re: A15 dyno results [and new head gasket needed] Dodgeman 2005/12/13 13:28
                 Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/14 12:01
                   Re: A15 dyno results [and new head gasket needed] Grunterhunter 2005/12/15 6:03
                     Re: A15 dyno results [and new head gasket needed] matbighat 2005/12/15 18:07
                       Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/16 13:38
                         Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/17 13:59
                           Re: A15 dyno results [and new head gasket needed] ptomli 2005/12/17 14:52
                             Re: A15 dyno results [and new head gasket needed] nicholas 2005/12/22 6:15
