Re: Which coil to use with electronic distributer?
The factory distributors do not use a capactive discharge system.
Some of the Datsun systems used a points coil with the electronic distributor. In this case, the ballast resistor is still used. With the resistor, the voltage will not be too high.
For best results with the blackbox A15 factory distributor, use coil Nissan part number 22433-H7280 or equivalent (Bosch 00200). This should work with most Mitsubishi or Hitachi distributors that don't use a ballast resistor. For a list of part numbers, see B310 Electronic Distributor Swap.
Posted on: 2006/1/5 5:18
Subject Poster Date
     Which coil to use with electronic distributer? SUNEE 2005/12/19 1:34
       Re: Which coil to use with electronic distributer? steveo 2005/12/19 1:42
         Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 1:46
       Re: Which coil to use with electronic distributer? Cable_Tie 2005/12/19 1:44
         Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 1:49
           Re: Which coil to use with electronic distributer? steveo 2005/12/19 2:03
             Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 2:07
               Re: Which coil to use with electronic distributer? Tham 2005/12/19 4:04
                 Re: Which coil to use with electronic distributer? Cable_Tie 2005/12/19 4:42
                   Re: Which coil to use with electronic distributer? blofly 2005/12/19 8:04
       Re: Which coil to use with electronic distributer? evilsim 2005/12/19 8:13
         Re: Which coil to use with electronic distributer? dattoman_1000 2005/12/19 10:58
           Re: Which coil to use with electronic distributer? dattodude 2005/12/19 14:41
             Re: Which coil to use with electronic distributer? dattoman_1000 2005/12/20 11:07
       Re: Which coil to use with electronic distributer? slimpickaus 2006/1/5 2:03
         Re: Which coil to use with electronic distributer? ddgonzal 2006/1/5 5:18
           Re: Which coil to use with electronic distributer? blofly 2006/1/5 5:56
