Browsing this Thread:
1 Anonymous Users
Re: Rear suspention for 1200s???!!!!! |
From Christchurch
I personally like the idea of a panhard rod, if not for only lowering the rear roll center a bit. Although that would only be an issue if you had changed the front roll center. Unfortunately it's all theoretical as i don't have a race car. People are split on whether it is worth it or not i would say there are just as many people for and against a panhard so i guess it comes down to you. it's been said if you have a number of locating holes in your panhard brackets so you can set up your panhard at different heights then you can adjust your rear roll center. If i had a race car i would want all the adjustability i could have so by using the above you have another degree of adjustment could be worth investigating some more.
Nick
Posted on: 2006/1/6 4:42
