Re: Plans for the future! (Turbo A12)
From Ipswich,QLD
So you want to build a turbo a12 like others have said choose the car you want ....
forget the decomp plate theres no real need for it .Atleast use a a14 head on an a12 as the head flows better .
read through the tech section and learn how to lock the diizzy up save a lot of detonation problems later on in the tunning process..
Make your flange for the manifold and start with buying some steam pipe .You should be able to pick up a good working turbo for under 150 $ and su carbys are cheep as .you will need a electric fuel pump the turbo will lean out and probablly blow on you due to lack of fuel...I have a name of a company that has a program on there profile cutter for the a14 flanges if you want one done ..cheers
Posted on: 2006/2/10 10:35
Subject Poster Date
     Plans for the future! (Turbo A12) datrat_dave 2006/2/9 10:05
       Re: Plans for the future! (Turbo A12) Freak 2006/2/9 10:29
         Re: Plans for the future! (Turbo A12) DVLDAT 2006/2/9 10:37
         Re: Plans for the future! (Turbo A12) datrat_dave 2006/2/9 10:39
           Re: Plans for the future! (Turbo A12) Anonymous 2006/2/10 0:04
             Re: Plans for the future! (Turbo A12) pro-240c 2006/2/10 1:38
               Re: Plans for the future! (Turbo A12) teretonga 2006/2/10 2:43
                 Re: Plans for the future! (Turbo A12) datrat_dave 2006/2/10 3:07
                   Re: Plans for the future! (Turbo A12) pro-240c 2006/2/10 4:52
                     Re: Plans for the future! (Turbo A12) kegs 2006/2/10 5:50
                       Re: Plans for the future! (Turbo A12) sidedraught 2006/2/10 6:25
                         Re: Plans for the future! (Turbo A12) tom210 2006/2/10 8:26
                           Re: Plans for the future! (Turbo A12) boofhead 2006/2/10 10:14
                             Re: Plans for the future! (Turbo A12) 120fly 2006/2/10 10:35
                               Re: Plans for the future! (Turbo A12) SLAM1024 2006/2/11 0:48
                                 Re: Plans for the future! (Turbo A12) datrat_dave 2006/2/14 4:36
                                   Re: Plans for the future! (Turbo A12) boofhead 2006/2/14 10:46
                                     Re: Plans for the future! (Turbo A12) datrat_dave 2006/2/14 12:34
