Re: What shock absorbers do you racers use?
From Adelaide, Australia
Ive got adjustable coupe konis for the rear of my sedan you have to lower the bottom shock mount to stop the shock bottoming out. yes they adjust by compressing the shock then turning either way for firmer/softer. There are kyb ajx (i think that what they are called) shocks that have a adjusting knob at the base of the shock, i dont know if they are worth looking into but really you cant go past a set of konis. Why wouldnt you have adj on the front only on the rear???
Posted on: 2006/2/16 13:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Subject Poster Date
     What shock absorbers do you racers use? 1200GXman 2006/2/16 13:24
       Re: What shock absorbers do you racers use? WhiteSedan 2006/2/16 13:36
         Re: What shock absorbers do you racers use? 1200GXman 2006/2/16 14:08
           Re: What shock absorbers do you racers use? WhiteSedan 2006/2/16 14:17
             Re: What shock absorbers do you racers use? Rallytwit 2006/2/16 16:22
       Re: What shock absorbers do you racers use? AdamBDA 2006/2/17 0:52
         Re: What shock absorbers do you racers use? datman55 2006/2/17 3:26
           Re: What shock absorbers do you racers use? stirlingmac 2006/2/17 4:11
             Re: What shock absorbers do you racers use? Freak 2006/2/17 6:27
               Re: What shock absorbers do you racers use? 1200GXman 2006/2/17 6:55
                 Re: What shock absorbers do you racers use? matty 2006/2/17 7:18
                 Re: What shock absorbers do you racers use? Widget 2006/2/17 7:56
                   Re: What shock absorbers do you racers use? 1200GXman 2006/2/17 8:21
                     Re: What shock absorbers do you racers use? LittleFireyOne 2006/2/17 9:03
                       Re: What shock absorbers do you racers use? Rallytwit 2006/2/17 16:20
                         Re: What shock absorbers do you racers use? B210sleeper 2006/2/17 18:27
                           Re: What shock absorbers do you racers use? Devious-Jet 2006/2/18 23:50
                           Re: What shock absorbers do you racers use? JD1200 2006/5/5 7:53
