Hr30 Skyline front struts into 1200
From New Zealand
Hey everyone i have a set of hr30 skyline front struts and would like to no wat i need to do to fit them into my 1200. i have measured them and they are 50mm longer from ball joint mount to the top of the strut tower bolts, so to lower the car 50mm i need to shorten the whole unit by 100mm.
wat is the best way do do this with a combo of springs and shortend shocks as i dont want to upset the geometry to much. also wat bottom arms to i use as the hr30s holes are wider. i herd these are the struts to use as the brakes are vented ec and alot larger in diameter thanks.
Posted on: 2006/2/17 9:51
Subject Poster Date
     Hr30 Skyline front struts into 1200 brocky41 2006/2/17 9:51
