Re: Open or locked diff for motorkana?
From Canberra
For slow speed stuff like Motorkhana's you are probably better off leaving the open centre in the car, you will get less understeer and low speed push out of the front end, turn in will be better also.
The only time it will cause you any problems is in very wet muddy conditions where you will struggle for grip, but everything is a compromise.
Posted on: 2006/2/22 22:48
Subject Poster Date
     Open or locked diff for motorkana? Ianey 2006/2/22 10:50
       Re: Open or locked diff for motorkana? Tyrie 2006/2/22 10:53
       Re: Open or locked diff for motorkana? 1200coupe 2006/2/22 22:48
         Re: Open or locked diff for motorkana? Rallytwit 2006/2/22 23:07
       Re: Open or locked diff for motorkana? Dodgeman 2006/2/22 23:10
         Re: Open or locked diff for motorkana? L18_B110 2006/2/22 23:21
           Re: Open or locked diff for motorkana? pro-240c 2006/2/23 1:55
             Re: Open or locked diff for motorkana? Cable_Tie 2006/2/23 2:40
               Re: Open or locked diff for motorkana? Ianey 2006/2/23 5:55
                 Re: Open or locked diff for motorkana? 1200coupe 2006/2/23 6:06
                   Re: Open or locked diff for motorkana? L18_B110 2006/2/23 7:25
                     Re: Open or locked diff for motorkana? Devious-Jet 2006/2/23 12:35
                       Re: Open or locked diff for motorkana? converted 2006/2/23 23:20
