Re: Wide body datto 1000 fastback coupe
Grunterhunter wrote:
Either way the clause implies a crossmember change, not just putting different suspension arms, hubs etc onto the same crossmember, so the vanette option may be a good way to go.
Like I said;
I recommend you read the guidelines clearly.
A stub axle is an axle, is it not?
Therefore if you change the stub axle the wheel track limit is like I previously stated.
A hub is not and axle, it is fitted to an axle.
Example - Dattoman_1000's brake swap. Although good as it is, it doesnt meet the DOT requirements for increased wheel track.
It is to do with the loads applied to the components. If you increase the wheel track by just hubs or wheels, it will place more load on the bearings and balljoints. But if you increase wheel track with another axle from a bigger heavier vehicle, the axle components will be within there tested load handleing range.
Its not that hard to understand if you read it for what it says. No guidelines are set on visual ergonomics. They are all set based on engineering principals.
I do believe there is a pic located in the photo album somewhere, of a 1000 engine bay showing its had 1200 strut towers fitted.
Posted on: 2006/3/6 10:27
Subject Poster Date
     Wide body datto 1000 fastback coupe myti4 2006/3/5 14:15
       Re: Wide body datto 1000 fastback coupe Dodgeman 2006/3/5 20:40
         Re: Wide body datto 1000 fastback coupe myti4 2006/3/6 0:43
           Re: Wide body datto 1000 fastback coupe Grunterhunter 2006/3/6 1:54
             Re: Wide body datto 1000 fastback coupe phunkdoktaspok 2006/3/6 4:25
               Re: Wide body datto 1000 fastback coupe Grunterhunter 2006/3/6 5:00
                 Re: Wide body datto 1000 fastback coupe myti4 2006/3/6 8:32
                   Re: Wide body datto 1000 fastback coupe Grunterhunter 2006/3/6 9:23
                     Re: Wide body datto 1000 fastback coupe phunkdoktaspok 2006/3/6 10:27
                       Re: Wide body datto 1000 fastback coupe sidedraught 2006/3/6 10:57
                         Re: Wide body datto 1000 fastback coupe myti4 2006/3/6 14:50
                           Re: Wide body datto 1000 fastback coupe DatsunSSS 2006/3/6 19:49
                             Re: Wide body datto 1000 fastback coupe phunkdoktaspok 2006/3/6 22:36
                               Re: Wide body datto 1000 fastback coupe DatsunSSS 2006/3/7 0:43
                                 Re: Wide body datto 1000 fastback coupe phunkdoktaspok 2006/3/7 2:41
                                   Re: Wide body datto 1000 fastback coupe LittleFireyOne 2006/3/7 4:05
                                     Re: Wide body datto 1000 fastback coupe myti4 2006/3/7 6:38
                   Re: Wide body datto 1000 fastback coupe qik1000 2006/3/6 9:41
                 Re: Wide body datto 1000 fastback coupe Ianey 2006/3/6 8:43
           Re: Wide body datto 1000 fastback coupe LittleFireyOne 2006/3/6 1:56
       Re: Wide body datto 1000 fastback coupe qik1000 2006/3/6 2:26
         Re: Wide body datto 1000 fastback coupe pager 2006/3/6 2:53
