Re: As you know an engine is nothing more than a big air pump...
From Burbank, CA
I'm kind of dreading a suck through turbo. At least i probably don't need the special seals, but I'd been hoping to use an intercooler, so that won't work in a suck through.
Is the improved mixing worth not having an intercooler?
what if there are 2 turbos, 1 to pressurize the intercooler and another to mix up the air and feed the engine? Or is that way more complicated than it needs to be.
Lpg really blends well, so maybe that's overkill.
just want to boost the CR up to about 12:1 to take advantage of the higher octane.
is the accelerator pump why petrol carbs seem less efficent? LPG mixers don't spray extra fuel when you mash on the throttle.
Posted on: 2006/3/10 2:29
|||\ 81 KPB310 /|||
Subject Poster Date
     As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/9 2:22
       Re: As you know an engine is nothing more than a big air pump... ddgonzal 2006/3/9 7:02
         Re: As you know an engine is nothing more than a big air pump... pro-240c 2006/3/9 7:59
           Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/9 16:06
             Re: As you know an engine is nothing more than a big air pump... Dodgeman 2006/3/9 20:21
               Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/9 20:39
                 Re: As you know an engine is nothing more than a big air pump... Mildman 2006/3/9 22:22
                   Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/9 22:30
                     Re: As you know an engine is nothing more than a big air pump... feral 2006/3/10 2:18
                       Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/10 2:29
                         Re: As you know an engine is nothing more than a big air pump... Mildman 2006/3/10 3:29
                           Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/10 4:03
                             Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/14 22:36
                               Re: As you know an engine is nothing more than a big air pump... wagon1200 2006/3/15 5:03
                                 Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/3/15 6:20
       Re: As you know an engine is nothing more than a big air pump... datsik 2006/4/11 16:40
         Re: As you know an engine is nothing more than a big air pump... B210sleeper 2006/4/11 18:06
