Re: su insulators
From Dallas TX
You can use British SU carb insulators which are available from aptfast.com. Here is a link: aptfast su carb parts They look a little different and the thickness may not be the same but they should work. I am 100% sure the HS4 type have the same dimensions (bore and bolt pattern), maybe H4 also. They should be the same size but I woudl double check with aptfast about that. The H4 ones they sell look nicer. Here's a picture:
If you can't order direct I would be happy to give you hand americo. I'm glad you finally found your carbs!
Michael
Posted on: 2006/3/15 21:36
Subject Poster Date
     su insulators DatsunSSS 2006/3/15 21:15
       Re: su insulators mperdue 2006/3/15 21:36
