Re: Custom Handbrake Setups??
From Sydney Australia
I had exactly the same problem with the borgwarner diff conversion. I made 90degree angles for the two brake lines that bolt into the two holes where the diff bummp stop used to be and like you said make a three way fitting for the joining part, only trouble is the cables always stretch and need adjusting and the hand brake is crapy at the best of times any ways (maybe not on yours but the borg hand brake sux) good luck
Posted on: 2006/3/22 6:05
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Subject Poster Date
     Custom Handbrake Setups?? Davo1200 2006/3/22 5:32
       Re: Custom Handbrake Setups?? Ianey 2006/3/22 5:36
         Re: Custom Handbrake Setups?? Ianey 2006/3/22 5:44
           Re: Custom Handbrake Setups?? 731200 2006/3/22 5:57
         Re: Custom Handbrake Setups?? Davo1200 2006/3/22 5:52
           Re: Custom Handbrake Setups?? 731200 2006/3/22 6:05
             Re: Custom Handbrake Setups?? phunkdoktaspok 2006/3/22 10:52
               Re: Custom Handbrake Setups?? Davo1200 2006/3/22 12:22
                 Re: Custom Handbrake Setups?? Ianey 2006/3/22 12:24
                   Re: Custom Handbrake Setups?? matty 2006/3/22 12:29
