Re: Gasket Sealant on Carburetor Mount ?
Your mechanic is correct:Quote:
My usual mechanic says no, the pad is a kind of fiber
These fiber gaskets need no sealant, and sealant should not be used. They can be reused time and again unless they are extremely hard and brittle.
If you don't have a gasket, you can use a fuel-rated silicone RTV sealant like the Dr. uses. Make sure the package says it is OK for gasoline.
Posted on: 2006/4/21 17:47
Subject Poster Date
     Gasket Sealant on Carburetor Mount ? Tham 2006/4/14 19:09
       Re: Gasket Sealant on Carburetor Mount ? Mildman 2006/4/19 1:38
       Re: Gasket Sealant on Carburetor Mount ? B210sleeper 2006/4/19 1:58
         Re: Gasket Sealant on Carburetor Mount ? Mildman 2006/4/19 9:17
       Re: Gasket Sealant on Carburetor Mount ? phunkdoktaspok 2006/4/19 9:47
         Re: Gasket Sealant on Carburetor Mount ? ddgonzal 2006/4/21 17:47
           Re: Gasket Sealant on Carburetor Mount ? B210sleeper 2006/4/22 5:06
