Re: Z Wheels?
From Burbank, CA
I have 14" 280zx wheels on my 210 ATM, i also have the whole 280zx turbo strut and different brakes. I needed a 1/4" spacer to clear my brakes, but other than that it fit. I have it lowered to where there is maybe 1.5" between the tire and the fender, nothing rubs( except some times in a big bump in the road, and not in a dangerous way. ), it might be good to raise it .5" I've heard you may need to flare the fenders if you have more wheel travel. My struts are very short and have a higher spring rate, but the dampers are almost as soft as they go because of the bad roads.
My tires are pirelli p4000 14x195x60 if you really look hard there are some 14x195x55 tires out there.
further answering your question....
13 - 15" wheels no wider than 6" with proper offset will fit the standard 210. I've also had 15x195x50's on this car with no trouble. Remember plus sizing. the car originally had 13x185x70 tires so as long as you keep it to 195 wide or less than it's easy.
Posted on: 2006/4/20 2:24
|||\ 81 KPB310 /|||
Subject Poster Date
     Z Wheels? dattson510 2006/4/20 2:05
       Re: Z Wheels? benddatsun 2006/4/20 2:10
         Re: Z Wheels? B210sleeper 2006/4/20 2:24
