Re: 120y starter motor
They're all the same: b110, b210, b310 starters ... If you buy a used one, ask if they have a warranty, and if they check the brushes.
Here's the things to look for:
- bushing is tight (shaft can't be wiggled)
- overrun clutch is tight (gear turns one way, but not backwards at all)
- brushes are not worn down all the way.
The last requires a partial dissassembly. The first two do not.
Posted on: 2006/5/2 17:36
Subject Poster Date
     120y starter motor FreaKerSea 2006/4/29 13:18
       Re: 120y starter motor nismo 2006/5/2 11:44
       Re: 120y starter motor DemonFreeman 2006/5/2 12:38
         Re: 120y starter motor ddgonzal 2006/5/2 17:36
