I need help with an ECU!!!
From Trinidad W.I.
Hi, I am doing an engine convertion on a Nissan E20 mini bus. I am installing a Nissan TD27 Turbo Intercooled diesel engine with a four speed transmission with overdrive. The transmission is electronic and hence it has an ECU. I need to get the wiring diagram or pin layout for the ECU in order to wire it up. If its not wired up the gears will not change. I would appreciate it if anyone can help me in getting this info. Thanks.
Posted on: 2006/5/3 16:20
Subject Poster Date
     I need help with an ECU!!! RMSPOWER 2006/5/3 16:20
       Re: I need help with an ECU!!! RMSPOWER 2006/5/8 22:16
         Re: I need help with an ECU!!! pager 2006/5/9 1:13
