Re: valve timing?
From Strand, South Africa
hhmm come to think of it I did tamper with the points before I checked/set my timming.
Tell me if this method is wrong cause i'm not sure if its the right way to do it. I take the dizzys cap off, rotate the engine till the points are at the highest point on the cam, adjust that distance to .50mm - .55mm (if my memory serves me correctly) with feelerblades and tighten points screw.
Posted on: 2006/5/10 13:55
Subject Poster Date
     valve timing? Losadel 2006/5/9 16:20
       Re: valve timing? B210guy 2006/5/9 17:47
         Re: valve timing? Losadel 2006/5/10 10:22
           Re: valve timing? 1200GXman 2006/5/10 11:08
             Re: valve timing? Losadel 2006/5/10 13:55
               Re: valve timing? 1200GXman 2006/5/10 15:50
                 Re: valve timing? WhiteSedan 2006/5/10 16:17
                   Re: valve timing? ddgonzal 2006/5/10 17:15
