Re: 79 210 engine swap possibilities
From Burbank, CA
that looks like a great fit.
engine mounts to the frame tails aren't a big deal if you want solid mounts.
I think if i were going to swap an engine it looks like that would be it. Every bit of weight possible would need to be moved to the back, i'd add weight to the back to get back to 51/49 with an engine like that.
so it's a 3 liter 6 cylinder, how many ft/lb? Is this the engine that every car i saw it in had caught fire? it was either this one or a toyota 3l 6cyl.
Tell me why these Vg30's are bad, Weight is one, what else is not good. What about vg30 5speed trannies?
Posted on: 2006/5/17 3:38
|||\ 81 KPB310 /|||
Subject Poster Date
     79 210 engine swap possibilities theclerk74 2006/5/16 7:55
       Re: 79 210 engine swap possibilities Dodgeman 2006/5/16 9:45
         Re: 79 210 engine swap possibilities hotrod88 2006/5/17 1:57
           Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 2:10
             Re: 79 210 engine swap possibilities ratdat_uk 2006/5/17 2:58
               Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 3:05
                 Re: 79 210 engine swap possibilities ddgonzal 2006/5/17 3:23
                 Re: 79 210 engine swap possibilities ratdat_uk 2006/5/17 3:30
                   Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 3:38
                     Re: 79 210 engine swap possibilities ratdat_uk 2006/5/17 4:03
                       Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 4:36
                         Re: 79 210 engine swap possibilities theclerk74 2006/5/17 4:54
                           Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 5:02
                             Re: 79 210 engine swap possibilities theclerk74 2006/5/17 5:23
                               Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 5:28
                                 Re: 79 210 engine swap possibilities theclerk74 2006/5/17 5:34
                                   Re: 79 210 engine swap possibilities ddgonzal 2006/5/17 6:26
                                     Re: 79 210 engine swap possibilities theclerk74 2006/5/17 7:34
                                     Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 19:04
                                       Re: 79 210 engine swap possibilities theclerk74 2006/5/17 19:27
                                         Re: 79 210 engine swap possibilities ratdat_uk 2006/5/18 12:25
                                           Re: 79 210 engine swap possibilities theclerk74 2006/5/18 12:34
                                             Re: 79 210 engine swap possibilities ratdat_uk 2006/5/18 14:10
                                       Re: 79 210 engine swap possibilities B210sleeper 2006/5/17 20:10
                                       Re: 79 210 engine swap possibilities mperdue 2006/5/17 21:48
                                         Re: 79 210 engine swap possibilities ddgonzal 2006/5/18 3:51
                                           Re: 79 210 engine swap possibilities nomore 2006/5/18 6:51
                                             Re: 79 210 engine swap possibilities B210sleeper 2006/5/18 7:53
                                               Re: 79 210 engine swap possibilities ratdat_uk 2006/5/18 8:17
                                                 Re: 79 210 engine swap possibilities theclerk74 2006/5/18 9:14
                                                   Re: 79 210 engine swap possibilities theclerk74 2006/5/18 9:22
                                                     Re: 79 210 engine swap possibilities sunny1046 2006/5/18 11:11
                                                       Re: 79 210 engine swap possibilities theclerk74 2006/5/18 11:22
                                                   Re: 79 210 engine swap possibilities ratdat_uk 2006/5/18 11:23
                                                     Re: 79 210 engine swap possibilities theclerk74 2006/5/18 12:05
           Re: 79 210 engine swap possibilities theclerk74 2006/5/17 3:58
