Re: Need some help if you guys could. Thanks
Not too shy to talk
From Prescott Arizona usa
alright, popped the manifold off today, and the ports on the head are a perfect circle, whereas the ones on the intake are oval, and look to be taller. The gasket appears to be the oval one as well. It doesnt look as though it would leak, but obviously the car doesnt like it...how do I find a circle port manifold to fix this? I have checked to local wreckers, and the local parts guys, no good....anyone have one? The intake I have is stamped h72 if that matters.
Posted on: 2006/6/2 0:38
Subject Poster Date
     Need some help if you guys could. Thanks beaterdat 2006/5/24 19:27
       Re: Need some help if you guys could. Thanks casper17000 2006/5/24 19:40
         Re: Need some help if you guys could. Thanks beaterdat 2006/5/24 19:43
           Re: Need some help if you guys could. Thanks casper17000 2006/5/24 19:47
             Re: Need some help if you guys could. Thanks mperdue 2006/5/24 19:54
               Re: Need some help if you guys could. Thanks beaterdat 2006/5/24 19:58
             Re: Need some help if you guys could. Thanks B210sleeper 2006/5/24 20:01
               Re: Need some help if you guys could. Thanks beaterdat 2006/5/24 20:10
                 Re: Need some help if you guys could. Thanks casper17000 2006/5/24 20:22
                   Re: Need some help if you guys could. Thanks B210sleeper 2006/5/24 21:59
                     Re: Need some help if you guys could. Thanks beaterdat 2006/5/24 23:02
                       Re: Need some help if you guys could. Thanks beaterdat 2006/5/25 23:46
                         Re: Need some help if you guys could. Thanks B210sleeper 2006/5/26 2:31
                           Re: Need some help if you guys could. Thanks beaterdat 2006/5/26 4:51
                             Re: Need some help if you guys could. Thanks beaterdat 2006/5/26 5:43
                               Re: Need some help if you guys could. Thanks Rallytwit 2006/5/26 15:55
                                 Re: Need some help if you guys could. Thanks beaterdat 2006/6/2 0:38
                                   Re: Need some help if you guys could. Thanks beaterdat 2006/6/2 0:54
                                     Re: Need some help if you guys could. Thanks killer1200 2006/6/2 1:02
                                       Re: Need some help if you guys could. Thanks beaterdat 2006/6/4 5:31
                                         Re: Need some help if you guys could. Thanks Duncan 2006/6/4 7:03
                                           Re: Need some help if you guys could. Thanks beaterdat 2006/6/5 14:57
                                             Re: Need some help if you guys could. Thanks blofly 2006/6/5 15:53
                                               Re: Need some help if you guys could. Thanks beaterdat 2006/6/5 16:50
                                       Re: Need some help if you guys could. Thanks mperdue 2006/6/5 22:27
