Re: will i get 100-110hp from a A14 with su's
From Brisbane, Narangba
The best thing about an SU type of carby is that it has a variable venturi. So if you have the correct needle for your engine the carbys should supply the correct air/fuel ratio through the whole rev range.
Posted on: 2006/6/19 11:22
Subject Poster Date
     will i get 100-110hp from a A14 with su's MattoRX7 2006/6/19 4:07
       Re: will i get 100-110hp from a A14 with su's matbighat 2006/6/19 5:05
         Re: will i get 100-110hp from a A14 with su's Freak 2006/6/19 6:40
           Re: will i get 100-110hp from a A14 with su's MattoRX7 2006/6/19 9:11
             Re: will i get 100-110hp from a A14 with su's D 2006/6/19 9:18
               Re: will i get 100-110hp from a A14 with su's mopar 2006/6/19 10:21
       Re: will i get 100-110hp from a A14 with su's carjunkie 2006/6/19 10:22
         Re: will i get 100-110hp from a A14 with su's L18_B110 2006/6/19 11:09
           Re: will i get 100-110hp from a A14 with su's Freak 2006/6/19 11:22
             Re: will i get 100-110hp from a A14 with su's dog160 2006/6/19 13:52
           Re: will i get 100-110hp from a A14 with su's Dodgeman 2006/6/19 14:18
             Re: will i get 100-110hp from a A14 with su's Rallytwit 2006/6/19 20:32
               Re: will i get 100-110hp from a A14 with su's R-fastmotorsport 2006/6/19 23:44
                 Re: will i get 100-110hp from a A14 with su's Rallytwit 2006/6/20 0:10
                   Re: will i get 100-110hp from a A14 with su's matbighat 2006/6/20 5:03
                     Re: will i get 100-110hp from a A14 with su's mopar 2006/6/20 10:46
                       Re: will i get 100-110hp from a A14 with su's sikyne 2006/6/20 12:26
                         Re: will i get 100-110hp from a A14 with su's Datsfullysik 2006/6/20 13:16
                           Re: will i get 100-110hp from a A14 with su's D 2006/6/20 14:40
                             Re: will i get 100-110hp from a A14 with su's mperdue 2006/6/20 14:52
                               Re: will i get 100-110hp from a A14 with su's Rallytwit 2006/6/20 17:18
