Re: Tie Rod Ends
From Townsville, Qld
Well I don't know if it helps but for 120y's there are 2 sizes, 10mm and 12mm. The later was used in later 120y's so my guess is it should be a 10mm threaded rod right? becuase 1200's had 10mm. Ask the number jockey bum at the shop to get you a 1200 one or something to try and don't take no for an answer.
Or I just thought that mabey your tie rods and stuff was taken from another type of car at some piont so Datsun stuff won't match up?
Posted on: 2006/6/26 14:47
Subject Poster Date
     Tie Rod Ends Razor 2006/6/26 12:22
       Re: Tie Rod Ends Razor 2006/6/26 13:45
         Re: Tie Rod Ends LittleFireyOne 2006/6/26 14:47
           Re: Tie Rod Ends Razor 2006/6/27 7:56
             Re: Tie Rod Ends LittleFireyOne 2006/6/27 9:05
