Re: Will a B-210 5-speed fit in a 1200?
From Sydney
I just fitted a 210 dogleg 5 speed to my coupe a few weeks ago. The mounts were a bit of a pain as they about 2 inchs back from the origanal 1200's mounts. However, i ended up making a nice
strong mount out of thick flat strap steel. Works a treat. I dont even think it had the reverse switch on it as nothing fouled the tunnel. Well i lied, a bolt of some sort on the box was hard
up against the drivers side 1200 mounts, so i had to sorta twist the whole engine and box. Kinda hard to explain so i'll move on. The gearbox yes cant take too much of a thrashing, but behind
a warm A14/15 its should hold up if u dont light up the bags every set of lights. I wont be booting my coupe too much as i know this is a weak link with 150hp and want the 5 speed to be still
working when i replace it with a toyota box in a couple of months. I am even thinking of rippin it out after only a couple of weeks and shoving a 4 speed back in for the time being. damn i
love datsuns...
Scotty
Davo
Posted on: 2001/2/2 2:52
Subject Poster Date
     Will a B-210 5-speed fit in a 1200? datsunf10 2001/2/1 7:40
       Re: Will a B-210 5-speed fit in a 1200? datsa73 2001/2/1 3:23
         Re: Will a B-210 5-speed fit in a 1200? ang94541 2001/2/1 4:38
         Re: Will a B-210 5-speed fit in a 1200? boltman97220 2001/2/1 6:27
           Re: Will a B-210 5-speed fit in a 1200? Davo1200 2001/2/2 2:52
             Re: Will a B-210 5-speed fit in a 1200? fester2au 2001/2/6 6:07
               Will a B-210 5-speed fit in a 1200? ratdat_uk 2001/2/6 6:43
       Will a B-210 5-speed fit in a 1200? wubbits 2001/2/5 3:05
