Re: residual pressure check valve
From Townsville, Qld
you know I just had a thought but it probably not worth much investigation. What if there is enough room in the master cylinder assembly to drill out that hole large enough and plug it up with a carby jet. That way you can change the pressure with the jetsize?Quote:
Daveman wrote:
What do all the kids with 1600's do when they upgrade to R31 rear discs?
For my rear discs I drilled a very small hole in the original valve to relieve residual pressure. As per what Dattodude said, perhaps this was the wrong things to do. Maybe I'll also find the rear brakes not doing much?
Posted on: 2006/7/22 22:37
Subject Poster Date
     residual pressure check valve PIGDOG 2006/7/22 1:39
       Re: residual pressure check valve boofhead 2006/7/22 4:26
         Re: residual pressure check valve dattodude 2006/7/22 6:24
           Re: residual pressure check valve boofhead 2006/7/22 7:25
             Re: residual pressure check valve dattodude 2006/7/22 7:31
               Re: residual pressure check valve PIGDOG 2006/7/22 11:01
                 Re: residual pressure check valve dattodude 2006/7/22 11:23
                   Re: residual pressure check valve Daveman 2006/7/22 15:12
                     Re: residual pressure check valve LittleFireyOne 2006/7/22 22:37
                       Re: residual pressure check valve dattodude 2006/7/22 23:17
                         Re: residual pressure check valve boofhead 2006/7/23 1:31
                           Re: residual pressure check valve PIGDOG 2006/7/23 1:39
