Re: polishing rocker cover
From Dallas TX
I went through this but in the end I wasn't able to get a good clear coat on it to keep it from rusting. Aluminum is easy but steel rusts so quickly especially when it gets hot. I tried to coat it with POR-15's "Glisten PC" clear coat that is designed for clearcoating polished steel and other metals. But it was very difficult to apply. I think it needed to be thinned much more than they suggested and then it would need multiple coats. Don't expect to spray a rattle can clear on polished steel because it won't hold up. It has to be an absolutely air/watertight seal otherwise the cancer will get in and it will spread.
Here's mine in the process of polishing: pic #1 I went through several grits of sandpaper by hand up to I think 1000, then 2 different buffing compounds down to a very fine grit, then polished with POR-15's "Artisan" polish (very very good polish by the way - highly recommended!!!)
Here's a pic on the engine: pic #2 You can't see it here but it is already starting to rust under the clearcoat. But now I have a spare valve cover and if I ever get time I'll probably just clean it up and paint it :) In my opinion it's not worth the time and effort because of the difficulty keeping the rust away.
Good luck.
Michael
Posted on: 2006/8/1 14:11
Subject Poster Date
     polishing rocker cover thebigJC 2006/8/1 11:46
       Re: polishing rocker cover mopar 2006/8/1 11:56
         Re: polishing rocker cover chris1200t 2006/8/1 12:43
           Re: polishing rocker cover thebigJC 2006/8/1 12:56
             Re: polishing rocker cover chris1200t 2006/8/1 13:16
       Re: polishing rocker cover mperdue 2006/8/1 14:11
         Re: polishing rocker cover blofly 2006/8/1 14:37
           Re: polishing rocker cover thebigJC 2006/8/5 1:09
             Re: polishing rocker cover B210sleeper 2006/8/5 1:49
               Re: polishing rocker cover thebigJC 2006/8/5 3:59
                 Re: polishing rocker cover blofly 2006/8/5 8:27
                   Re: polishing rocker cover thebigJC 2006/8/5 12:02
                     Re: polishing rocker cover Tommy-G 2006/8/6 5:44
                       Re: polishing rocker cover evilbetty 2006/8/6 12:00
                         Re: polishing rocker cover Rainz 2006/8/6 19:03
                           Re: polishing rocker cover B210sleeper 2006/8/6 19:16
