Re: STEERING BOX ADJUSTMENT
From Sydney, Australia
Nissan might still have them, as they are still using the same box in South Africa.
But it's easier to collect them at the wreckers, there are about 4 different shim sizes for the tube/column endfloat adjustment. Should only need one of each thickness for your collection. You can sollect them from various Datsun models.
For me, it's a mix and match affair. Collect several boxes based on my tests, loosening off the adjuster and checking for sector shaft bushes. I haven't looked for a supplier yet, because I had a good set 'in stock' from years of collecting parts.
A good steering unit will:
- not have a worn top bearing near the steering wheel..that's the sign the car has done more than 150000miles.
- not have any sideways play in the sector shaft.
- have minimal free play on the steering in the centre position, after you tighten down the lash while on full lock. This shows how much wear on the ballnut/sector shaft gear in centre position.
Posted on: 2006/8/19 23:42
Subject Poster Date
     STEERING BOX ADJUSTMENT LONGBROW 2006/8/18 21:08
       Re: STEERING BOX ADJUSTMENT teretonga 2006/8/18 23:17
       Re: STEERING BOX ADJUSTMENT dattodude 2006/8/18 23:36
         Re: STEERING BOX ADJUSTMENT LONGBROW 2006/8/19 1:41
         Re: STEERING BOX ADJUSTMENT Turboute 2006/8/19 1:58
           Re: STEERING BOX ADJUSTMENT dattodude 2006/8/19 11:25
             Re: STEERING BOX ADJUSTMENT ddgonzal 2006/8/19 19:10
               Re: STEERING BOX ADJUSTMENT dattodude 2006/8/19 23:42
             Re: STEERING BOX ADJUSTMENT Turboute 2006/8/20 1:02
       Re: STEERING BOX ADJUSTMENT ade 2006/8/19 8:54
         Re: STEERING BOX ADJUSTMENT dattodude 2006/8/19 11:21
       Re: STEERING BOX ADJUSTMENT Serial-Killa 2008/12/6 16:17
         Re: STEERING BOX ADJUSTMENT ddgonzal 2008/12/6 18:45
