Re: R30 Stumpy VS. CA18 'Long' box
From Perth WA
Daveman: will the l series shaft suit both gearbox's? or only one of them if so which one?? Cheers
Short-coupe: with the stanza shaft which box did you use? also are you running an r31 borgy diff? if so are you saying that the stanza shaft had the correct yokes just needed to be shortened and went staright in? thanks for all your help guys
Posted on: 2006/9/13 5:38
Subject Poster Date
     R30 Stumpy VS. CA18 'Long' box hcope86 2006/9/13 2:16
       Re: R30 Stumpy VS. CA18 'Long' box Daveman 2006/9/13 2:43
         Re: R30 Stumpy VS. CA18 'Long' box short-coupe 2006/9/13 4:59
           Re: R30 Stumpy VS. CA18 'Long' box hcope86 2006/9/13 5:38
             Re: R30 Stumpy VS. CA18 'Long' box short-coupe 2006/9/13 13:04
       Re: R30 Stumpy VS. CA18 'Long' box sssute 2006/9/13 11:35
         Re: R30 Stumpy VS. CA18 'Long' box dattodude 2006/9/13 12:02
