Re: Burnt Points ?
From Bunbury Western Australia
yeah the ballast resistor is to drop the voltage down when the engine has started, if he is not using a ballast resistor and just using straight 12V to the coil then that would also wear the points pre-maturely
Posted on: 2006/9/14 2:49
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Subject Poster Date
     Burnt Points ? CCG 2006/9/13 20:05
       Re: Burnt Points ? Dodgeman 2006/9/13 21:45
         Re: Burnt Points ? B210sleeper 2006/9/14 0:45
           Re: Burnt Points ? blofly 2006/9/14 2:49
             Re: Burnt Points ? CCG 2006/9/17 22:59
