Browsing this Thread:
1 Anonymous Users
reground cam, setting valve timing |
From Bunbury Western Australia
I have a reground cam and am wondering how I should go about setting up the valve timing. I don't know if I need to set it up with dial gauges and degree wheels or just line it up how the manual says to do it, I mean the locating dowel on the cam would still have the sprocket loacated in the same position so could I just line up the dowel and crank key way like the book basically says? The cam spec sheet says it has: at .050 timing inlet opens 7 BTDC, closes 43 ABDC, duration 229 exhaust opens 45 BBDC, closes 5 ATDC, duration 229 lobe sepperation 109 valve lift .4425 both intake and exhaust valve lash for both intake and exhaust is .016
Posted on: 2006/10/12 14:07
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
