Re: ignition timing and advance setting
From Bunbury Western Australia
my understanding with this dizzy used on twin sidedraught systems is not to worry about vacuum advance and to set the base ignition timing at between 10-14 degrees. I don't think sidedraughts have ported vacuum advance outlets mainly because they don't generate enough vacuum with 4 throttles.
I think R-Fastmotorsport uses that set up on his engine
Thats why I was wondering if I should try it without vacuum advance hooked up, but I will give it some more attention before I give up
Posted on: 2006/11/1 8:02
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Subject Poster Date
     ignition timing and advance setting blofly 2006/11/1 5:38
       Re: ignition timing and advance setting 3Rotor 2006/11/1 6:03
         Re: ignition timing and advance setting Dodgeman 2006/11/1 7:17
           Re: ignition timing and advance setting blofly 2006/11/1 7:27
             Re: ignition timing and advance setting Ronald 2006/11/1 7:37
               Re: ignition timing and advance setting blofly 2006/11/1 8:02
