Re: Can I fit my GX distributor in a A14 block?
From South Africa, Bloemfontein
will help as his spare head has been shaved to the max permitted.
Hahaaaaaaaaaaaa
Dodgeman, I can proudly say I have 2 spare GX cylinder heads. The one is shaved to the max which I plan to get rid of. The other one is 73.9mm thick and according to the cylinder head guy is within factory specs.
He said 73mm is the max skimmed thickness.
I am planning to use the one that is currently on my engine.
So actually I have 3 GX cylinder heads where one is currently in use on my GX engine.
Posted on: 2006/11/23 10:05
1977 Datsun 1200GX
Subject Poster Date
     Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/22 13:11
       Re: Can I fit my GX distributor in a A14 block? WhiteSedan 2006/11/22 13:14
         Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/22 13:19
           Re: Can I fit my GX distributor in a A14 block? WhiteSedan 2006/11/22 13:23
             Re: Can I fit my GX distributor in a A14 block? WhiteSedan 2006/11/22 13:25
         Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/22 13:21
           Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/22 13:27
             Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/22 13:34
               Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/22 13:48
                 Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/22 14:21
                   Re: Can I fit my GX distributor in a A14 block? Rallytwit 2006/11/22 17:22
                     Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/23 5:57
                       Re: Can I fit my GX distributor in a A14 block? kululadotgroen 2006/11/23 6:42
                         Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/23 8:32
                           Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/23 9:19
                             Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/23 9:23
                           Re: Can I fit my GX distributor in a A14 block? kululadotgroen 2006/11/23 9:34
                             Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/23 9:49
                               Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/23 10:05
                                 Re: Can I fit my GX distributor in a A14 block? Dodgeman 2006/11/23 10:17
                                   Re: Can I fit my GX distributor in a A14 block? kululadotgroen 2006/11/23 11:28
                                     Re: Can I fit my GX distributor in a A14 block? 1200GXman 2006/11/23 11:57
