alloy heads
From adelaide
Well i let my car overheat pritty badly last weekend (was boiling steam from the bonnet and was 115degrees C by the time i pulled over). Consequenly i think i have blown the head gasket, the engine uses more coolant than fuel, milky oil, steam out the catch can etc. Also it hydraulic locked last time i tryed cranking it over and sounds like a 2cyl!
My question is will/could my alloy head be stuffed because of this(cracked/warped etc) or are they fairly tough?
Unfortunatelly i wont have time to get it tested and ill have to chuck a fresh gasket in and hope for the best so i can come on the S.A dyno/cruise Ill be doing it tomorrow and ill take some pics
Posted on: 2007/1/26 8:27
1200 restoration project moving slower than it actually is
Subject Poster Date
     alloy heads sikdatto1200 2007/1/26 8:27
       Re: alloy heads Mildman 2007/1/26 8:29
       Re: alloy heads sikdatto1200 2007/1/26 8:57
         Re: alloy heads PIGDOG 2007/1/27 1:53
           Re: alloy heads ddgonzal 2007/1/27 3:10
             Re: alloy heads sikdatto1200 2007/1/29 21:56
               Re: alloy heads FAZPIOES 2007/1/29 22:22
               Re: alloy heads Ronald 2007/1/29 22:35
                 Re: alloy heads sikdatto1200 2007/1/29 22:58
                   Re: alloy heads Ronald 2007/1/29 23:03
                     Re: alloy heads Tyrie 2007/1/30 0:07
                       Re: alloy heads sikdatto1200 2007/1/30 0:23
                         Re: alloy heads Tyrie 2007/1/30 0:39
                           Re: alloy heads sikdatto1200 2007/1/30 0:52
                             Re: alloy heads PIGDOG 2007/1/30 2:23
                               Re: alloy heads Mildman 2007/1/30 4:31
