Re: Metal in my A15's oil, revisited.
From Flinders View, QLD
There is some big chunks in there. You say they are non magnetic whick would rule out oil pump gears cause they would be steel. Could be the pump housing. If you still have the oil send a sample away to get tested if you could be bothered. You are on the money with the valve stem seals, they cause smoke on start up. As lagwagon is saying, if you are going throught the trouble of doing the head, might as well inspect/repair the bottem end as well.
Posted on: 2007/2/23 9:22
Just trying to put the bloody puzzel back together
Subject Poster Date
     Metal in my A15's oil, revisited. AndyNXSE210 2007/2/22 22:22
       Re: Metal in my A15's oil, revisited. LAGWAGON 2007/2/23 0:14
         Re: Metal in my A15's oil, revisited. BUNDY351 2007/2/23 9:22
           Re: Metal in my A15's oil, revisited. AndyNXSE210 2007/2/23 17:49
             Re: Metal in my A15's oil, revisited. Dodgeman 2007/2/23 18:00
       Re: Metal in my A15's oil, revisited. B210sleeper 2007/2/23 23:55
         Re: Metal in my A15's oil, revisited. AndyNXSE210 2007/2/24 2:04
