Re: Bleeding up brakes..... Dry lines.
From Tamworth, NSW
Coops wrote:
All the lines are clean...
Using the correct technique.. Master cylinder still won't bleed up.
Thinking the master cylinder is shagged.
If you where pumping it while it was dry in the cylinder maybe it chewed the seals out Just a thought
Posted on: 2007/3/6 16:09
Project coupe:
Just drive it
Subject Poster Date
     Bleeding up brakes..... Dry lines. Coops 2007/3/5 13:24
       Re: Bleeding up brakes..... Dry lines. benny 2007/3/5 13:28
       Re: Bleeding up brakes..... Dry lines. Dodgeman 2007/3/5 16:49
       Re: Bleeding up brakes..... Dry lines. phunkdoktaspok 2007/3/5 18:17
         Re: Bleeding up brakes..... Dry lines. PIGDOG 2007/3/5 18:38
           Re: Bleeding up brakes..... Dry lines. dattoman_1000 2007/3/5 19:19
             Re: Bleeding up brakes..... Dry lines. phunkdoktaspok 2007/3/5 22:10
       Re: Bleeding up brakes..... Dry lines. ade 2007/3/5 22:49
         Re: Bleeding up brakes..... Dry lines. Coops 2007/3/6 15:43
           Re: Bleeding up brakes..... Dry lines. Burke_a_lot 2007/3/6 15:51
             Re: Bleeding up brakes..... Dry lines. dattoman_1000 2007/3/6 16:05
           Re: Bleeding up brakes..... Dry lines. pager 2007/3/6 16:09
             Re: Bleeding up brakes..... Dry lines. phunkdoktaspok 2007/3/6 16:36
               Re: Bleeding up brakes..... Dry lines. Coops 2007/3/11 7:07
