Re: The detonation thread
From Stray-ya
sikdatto1200 wrote:
Its an injection setup using a haltech ecu, the afr is just a jaycar one, not the most accurate thing but still gives you a fair idea whats going on, im going to do a water injection system using $100 high pressure pump and correct jet, and using adjustable hobs switch and a solonoid etc, should be under $300 me thinks
Injection eh, you spoilt bast@rd!!
what water pump are you using and where is it from?
For my setup, all I need is a switch on the secondary throttle- Boost is directly proportional to throttle opening, so a simple throttle switch will do the job
I was thinking of using a stainless water filled fire extinguisher, about 1/3 full of water/meth. Rig some high pressure pipework to the inlet with an appropriate size jet and mechanical activation (throttle opening) then just add water/meth + 100psi from your local servo when you fill up.
the only problem is pressure drop/ flow changes as it discharges, and finding a stainless fire extinguisher in the right size.
Posted on: 2007/3/13 15:53
Utes and Roots
Subject Poster Date
     The detonation thread sikdatto1200 2007/3/9 16:54
       Re: The detonation thread pager 2007/3/9 17:59
         Re: The detonation thread sikdatto1200 2007/3/9 18:10
           Re: The detonation thread woody 2007/3/9 18:48
             Re: The detonation thread sikdatto1200 2007/3/9 19:06
               Re: The detonation thread woody 2007/3/9 19:20
             Re: The detonation thread sikyne 2007/3/9 20:10
               Re: The detonation thread Dodgeman 2007/3/9 23:15
                 Re: The detonation thread matty 2007/3/10 7:41
                 Re: The detonation thread A14force 2007/3/10 7:50
                   Re: The detonation thread pepper 2007/3/10 7:57
                     Re: The detonation thread sikdatto1200 2007/3/12 16:29
                       Re: The detonation thread sikyne 2007/3/13 10:26
                         Re: The detonation thread SunnyDaze 2007/3/13 10:34
                           Re: The detonation thread sikyne 2007/3/13 10:49
                             Re: The detonation thread Grunterhunter 2007/3/13 13:28
                               Re: The detonation thread sikdatto1200 2007/3/13 14:17
                                 Re: The detonation thread A14force 2007/3/13 15:28
                                 Re: The detonation thread Grunterhunter 2007/3/13 15:53
                                   Re: The detonation thread sikdatto1200 2007/3/13 18:49
                                     Re: The detonation thread PIGDOG 2007/3/14 23:16
                                       Re: The detonation thread sikdatto1200 2007/3/15 7:25
                                         Re: The detonation thread PIGDOG 2007/3/15 10:08
                                     Re: The detonation thread Grunterhunter 2007/3/19 3:52
                                       Re: The detonation thread sikdatto1200 2007/3/19 3:59
                                         Re: The detonation thread Grunterhunter 2007/3/21 20:43
       Re: The detonation thread Burke_a_lot 2007/3/9 18:03
