Re: Fitting the 63A box.
From Brisbane
Yes Craig is right about my method. Sorry I thought you just wanted to know about the gearbox itself going in. The Hydro clutch install is the worst part. I used a 180b clutch clyinder lined it up with the clutch pedal (which was right next to the brake master in the thickest part to aviodf flex), then I just shortened the linkage on the clyinder to fit perfect to the stock pedal. Works perfect, I didnt wanna piss around with other pedal's etc
Posted on: 2007/3/24 1:34
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Subject Poster Date
     Fitting the 63A box. A14force 2007/3/23 2:29
       Re: Fitting the 63A box. 1200GXman 2007/3/23 2:35
         Re: Fitting the 63A box. B120dat 2007/3/23 2:43
           Re: Fitting the 63A box. 3Rotor 2007/3/23 3:04
       Re: Fitting the 63A box. A14force 2007/3/24 0:39
         Re: Fitting the 63A box. converted 2007/3/24 0:59
           Re: Fitting the 63A box. B120dat 2007/3/24 1:34
             Re: Fitting the 63A box. A14force 2007/3/24 23:06
       Re: Fitting the 63A box. evilsim 2007/12/4 12:46
         Re: Fitting the 63A box. ddgonzal 2007/12/4 18:13
