Re: URGENT HELP needed. Gearbox jammed
Pull the pin & lift the gear lever out. I think that you will find that the gearbox is in neutral & the gear lever has jumped out of the selectors & is in the fifth gear posituon, stuck there on the wrong side of a selector rail.
If it really IS in neutral, then refit the lever & don't be so 'vigorous' with the shift untill after the nationals when you will have more time to see what's worn & needs repair or replacement, to ensure it doesn't happen again.
Posted on: 2007/4/3 2:28
Love your Datsun.
Treat it well.
Subject Poster Date
     URGENT HELP needed. Gearbox jammed Daveman 2007/4/3 1:20
       Re: URGENT HELP needed. Gearbox jammed Mildman 2007/4/3 1:59
       Re: URGENT HELP needed. Gearbox jammed Dodgeman 2007/4/3 2:28
         Re: URGENT HELP needed. Gearbox jammed Daveman 2007/4/3 10:24
           Re: URGENT HELP needed. Gearbox jammed SunnyDaze 2007/4/3 12:13
             Re: URGENT HELP needed. Gearbox jammed matty 2007/4/4 7:26
               Re: URGENT HELP needed. Gearbox jammed Mildman 2007/4/4 11:23
