Re: datto1200 strut swaps. which one? :(
I've just fixed my bottoming out Stanza struts temporarily.
I pulled out my shock inserts and chopped the fitting lugs off the bottom and gained about 15mm. I then had to shorten the strut tube by the same length. Then cut off and re-attached the spring perches about 15mm higher.
It raised the car a little but I've gained more than an extra inch of travel. Now no more bottoming out
EDIT: this is using a king spring low and with a CA18 which adds a bit more weight on the front end.
Posted on: 2007/4/19 13:16
Subject Poster Date
     datto1200 strut swaps. which one? :( Matto1kUte 2007/4/19 7:07
       Re: datto1200 strut swaps. which one? :( BigD 2007/4/19 7:41
       Re: datto1200 strut swaps. which one? :( cheater_5 2007/4/19 8:30
         Re: datto1200 strut swaps. which one? :( WhiteSedan 2007/4/19 10:52
           Re: datto1200 strut swaps. which one? :( WhiteSedan 2007/4/19 10:55
             Re: datto1200 strut swaps. which one? :( Anonymous 2007/4/19 11:08
               Re: datto1200 strut swaps. which one? :( Daveman 2007/4/19 13:16
                 Re: datto1200 strut swaps. which one? :( Matto1kUte 2007/4/19 23:10
           Re: datto1200 strut swaps. which one? :( BigD 2007/4/20 6:05
             Re: datto1200 strut swaps. which one? :( WhiteSedan 2007/4/20 6:14
