Re: Suggestions to Reduce Understeer
From Sydney , NSW
Interesting points - good for mulling over.
My reading of late has me looking at the rear end of my car to assist the front - sounds strange but aparrently true. I have a picture at my last OP supersprint which shows it perfectly. Leaf sprung live axles have roll understeer built in by the manufacturer and fortunately there is a simple cure - I'm hoping so anyway!! My car is suffering from a bit of diagonal transfer with an outside rear taking too much load and unloading the opposite side front - so what can appear a front suspension issue can be actually a small problem being magnified by another - in this case, the rear. Suspension is rarely a black and white science so read up and ask questions because everyone has a theory
I agree that 6 deg neg is a little steep - 4 to 4.5 would be max I have been told.
Driving style is another indicator as pointed out earlier - and if you have a locked diff. If you do have a locker, you will either be braking, on the gas, or understeering - go or stop - if you don't DRIVE through corners with a locked diff the diff will tend to drive you
Hope this thread continues - will be a good learning tool for everyone.
Cheers
Posted on: 2007/4/21 11:56
All torque, no traction
A division of "My mate's ....." engineering
Subject Poster Date
     Suggestions to Reduce Understeer matty 2007/4/20 15:53
       Re: Suggestions to Reduce Understeer Daveman 2007/4/20 16:46
         Re: Suggestions to Reduce Understeer matbighat 2007/4/20 17:33
           Re: Suggestions to Reduce Understeer Cameron_Datto 2007/4/20 21:07
             Re: Suggestions to Reduce Understeer matbighat 2007/4/20 21:47
             Re: Suggestions to Reduce Understeer benny 2007/4/20 21:55
               Re: Suggestions to Reduce Understeer converted 2007/4/20 23:35
                 Re: Suggestions to Reduce Understeer L18_B110 2007/4/21 2:14
                   Re: Suggestions to Reduce Understeer datsik 2007/4/21 5:18
                     Re: Suggestions to Reduce Understeer R-fastmotorsport 2007/4/21 11:56
                       Re: Suggestions to Reduce Understeer matbighat 2007/4/21 17:47
                         Re: Suggestions to Reduce Understeer converted 2007/4/21 19:10
                           Re: Suggestions to Reduce Understeer Cameron_Datto 2007/4/21 20:57
                             Re: Suggestions to Reduce Understeer benny 2007/4/21 21:31
                               Re: Suggestions to Reduce Understeer Cameron_Datto 2007/4/21 21:58
                                 Re: Suggestions to Reduce Understeer matty 2007/4/21 22:12
                                   Re: Suggestions to Reduce Understeer Cameron_Datto 2007/4/21 22:46
                                     Re: Suggestions to Reduce Understeer matty 2007/4/23 17:25
                             Re: Suggestions to Reduce Understeer matty 2007/4/21 21:49
