Could be worlds dumbest question but need the answer!!!
I have a 4speed box(t40) on a 1.6 4a motor.
It has a hydraulic clutch.
My question is
how does the clutch master cylinder work with the pedal????
Does the rod have to be pushed in and bolted on to pedal then when you press the pedal it will pull back?????
If this is so do you have to bleed after or something to get the peddle back up????
Or do i have to run i different set up or somehow put this under the dash in the car???
And finaly if it does go on outside like i said has any1 made spacers or a custom rod and pin so it works????
Any help or ideas appreciated
But if i can i want to run the standard master cylinder
Oh yeh also
wil i have problem putting a 120y booster or 180b after putting a clutch master cylinder???
Dont look like much room.
Posted on: 2007/4/22 2:07
Subject Poster Date
     Could be worlds dumbest question but need the answer!!! Demo 2007/4/22 2:07
       Re: Could be worlds dumbest question but need the answer!!! Ronald 2007/4/22 2:47
         Re: Could be worlds dumbest question but need the answer!!! Demo 2007/4/22 2:59
       Re: Could be worlds dumbest question but need the answer!!! MarkP 2007/4/22 3:07
         Re: Could be worlds dumbest question but need the answer!!! phunkdoktaspok 2007/4/22 3:12
           Re: Could be worlds dumbest question but need the answer!!! Demo 2007/4/22 12:07
             Re: Could be worlds dumbest question but need the answer!!! Demo 2007/4/22 12:13
       Re: Could be worlds dumbest question but need the answer!!! kululadotgroen 2007/4/22 19:18
         Re: Could be worlds dumbest question but need the answer!!! Demo 2007/4/23 2:44
