Re: Standard 1200 Gearbox X Member Wanted
From Canberra
at least some of the 120Y ones are different, the gearbox crossmember sits lower in the tunnel I believe and should be wider...
I'm not 100% sure but thats why I needed the humps that the Xmember bolts to from you PIGDOG because 120Y ones were bigger.
Posted on: 2007/4/24 7:13
Subject Poster Date
     Standard 1200 Gearbox X Member Wanted Buff 2007/4/23 7:06
       Re: Standard 1200 Gearbox X Member Wanted PIGDOG 2007/4/23 10:14
         Re: Standard 1200 Gearbox X Member Wanted BAD310 2007/4/23 11:54
           Re: Standard 1200 Gearbox X Member Wanted blackhowler 2007/4/24 4:24
           Re: Standard 1200 Gearbox X Member Wanted dog160 2007/4/24 5:56
             Re: Standard 1200 Gearbox X Member Wanted PIGDOG 2007/4/24 7:04
               Re: Standard 1200 Gearbox X Member Wanted Tyrie 2007/4/24 7:13
                 Re: Standard 1200 Gearbox X Member Wanted Tyrie 2007/4/24 7:18
                 Re: Standard 1200 Gearbox X Member Wanted PIGDOG 2007/4/24 7:20
